跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
iPhone doesn't start after battery replacement
Hi,
I replaced the iPhone 6s plus battery. I hope I did it correctly. Once I put everything back, my phone won’t turn on. I thought it’s because the battery that I received isn’t full. Hence thought of charging it.
When connected to the charger, the iPhone is stuck in the boot loop. It never starts. If the charger is disconnected then the iPhone doesn’t turn on at all (just black screen).
Not sure where the problem is - whether the connections to the chip were are wrong or the connection to the battery is wrong or something else.
I can’t test it with the older battery, as it got bent when replaced.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
even if your old battery is bent, doesn’t necessarily mean it’s broken, you can still use it for testing to cross check the new battery.
reconnect the old battery (provided it’s not damaged from the removal), reconnect the screen ( you don’t need to put the bracket plates back on). if you can, put a piece of corrugated cardboard (or use anti-static foam) between the screen and base to prevent shorting and you can still turn the phone back on. you don’t need to completely re-assemble the phone to test it. this way you can at least see the what the phone does with the old battery (provided it still works).
if it works with the old battery, but not the new one, other than jumping to “it’s a bad battery”, i’m not sure what to tell you. personally, i’ve never had a battery issue cause problems like this. one thing to try, if it’s not already at the latest IOS, maybe upgrade it before trying the new battery again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vijay S Chadalavada 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 32
