跳转到主内容
My smartband has been on charge for the past 3 days. Can't charge it.
My smartband has been on charge for the past 3 days. It has not been used for a long period of time. I want to use it now but its not turning on. I tried putting it on charge but no response whatsoever.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
If the smartband has not been used or has not been kept charged for a long time then most probably the battery has become depleted beyond recovery and needs to be replaced.
I cannot find a guide or video that shows how to open the smartband but have found this disassembly video of a Huawei Band (model unknown) which may be of some help.
Replacement batteries are available online. Just search for Huawei Band 3 Pro battery to get results for suppliers that suit you.
这个答案有帮助吗?
得分 1
6条评论:
Thank you will look for guide
完成的
I can't seem to find the battery. Can you find one for me?
Thank you
完成的
@Nostalgic
There was a supplier linked in my answer above.
完成的
The price of shipping is more than than the battery itself.
完成的
@Nostalgic
Can only suggest then that you open the smartband and check if the battery has a model number printed on it.
If so search online using the model number only to hopefully find suppliers.
The model number printed on the battery that I linked only gives results for the supplier I linked and it seems like it is just a compatible replacement and not an identical replacement.
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Nostalgic 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 30
总计 330
