Screen stripes appear when cold temperature
Lenovo ideapad 520-15IBK
When computer contacts with cold temperature or after start/sleep appear stripes until it warms up. Turning maximum brightness helps remove them faster.
Lines appear vertically where is lighter color.
They are not visible on the printscreen.
I want to know should I replace the screen.
Also find a schematics so I can reconnect screen just in case.
2条评论
Where to buy a screen? And is there a way to identify correct name of the screen before disassample? May be on official site by serial number?
To be sure it is screen break I think i need to connect separately aither pc or screen. I ask in repair shop if they can do this.
由 internet910@gmail.com 完成的
@internet910
Try connecting the laptop to an external monitor just to verify that it is a screen problem and not a motherboard problem.
If the external monitor also shows the same problem does your particular model have one GPU (integrated with CPU) or 2, i.e. integrated Intel GPU + discrete Nvidia GPU?
If 2 try switching to the other one (when you can) as the primary display adapter and check if the problem occurs as well.
由 jayeff 完成的
