跳转到主内容
Valve Steam Controller, released November 10th 2015. Model 1001.
20 个问题 查看全部
My right bumper isn't working
I was playing a game and was pressing and holding this button a lot. Suddenly, it stopped working. I ran the diagnose on Big Picture mode and when I pressed it really hard it was detected, which led me to believe the problem was with the button piece and not the “sensor”. I haven’t tried opening it yet. How can I fix it?
Update (12/19/2021)
I opened yesterday and can say for sure now it’s the button.
I’m thinking the only way to fix this now is to 3D print another piece
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
9 out of 10 times its the sensor, not the button itself.
the only way youre going to fix it is by opening it.
这个答案有帮助吗?
得分 0
3条评论:
@madame can you post a picture of the sensor also? but i think i see what youre talking about
完成的
@logixal I think I posted a picture as an update on this post. The piece of plastic broke, but the electronic part seems intact
完成的
oooo i see, is the other part of it inside the controller? possible to superglue it? @madame
完成的
添加一条评论
Most likely to fail component is actually the small, thin and uniquely shaped flange that activate the right and left bumpers. They are slightly paddle shaped and extend out from the oddly shaped bracket they are a part of on a narrow neck that appears extremely fragile. Their known longevity is a testament to the design of the whole controller as they seem to last far beyond what one would assume. When they DO break however, the bumper is totally useless and since they are only a piece sticking out of a larger whole (and Valve no longer makes these controllers or parts) to replace it is an exercise involving more parts and areas than necessary, cannibalizing another Steam controller, or desperately searching for an improbable find online. Crafting a replacement is far more likely an option and this has its own issues.. There is a youtube video where a guy uses a tape measure for its type of metal material as the source for the creation of a replacement... I recommend it if this is what you are dealing with.
这个答案有帮助吗?
得分 0
添加一条评论
That's the trigger mount. Search "steamworks controller cad release" . If you have a 3d printer you can just print a new piece.
Look for the files:
ZIP archive for left trigger mount
ZIP archive for right trigger mount
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyogrefraga 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 28
总计 1,041
