跳转到主内容
The Razer Blade (2018) is a 15.6-inch gaming laptop released in May 2018.
26 个问题 查看全部
How do you fix the headset jack
The port itself is broken, how do you replace it? This is a Razer Blade 15 Mercury White.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@largesushi that jack is soldered to the motherboard. So, if you want to replace it, you will have to remove the motherboard first. Use something like this guide to do so. Now you have to unsolder the old port and replace it with a new one. The problem you might be run into is finding a proper replacement. You can always check places like mouser. com, digikey.com or Jameco.com as well as others for a part that might fit. Ultimately its a lot of work but it can be done. May be you want to consider a USB audio adapter to use for your Razer Blade.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Largesushi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 25
总计 298
