跳转到主内容
加入维修社区 - 创建账户
Where can I go to get my screen repaired?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
deborah mateo what exact model Chromebook is this? There should be a sticker on the bottom of your Chromebook, let us know what it says.
完成的
添加一条评论
1个答案
Most Chromebooks use similar screens - the issue is if it’s LVDS, or iDP in many cases. So say the Dell screen is too expensive - you can often source it from an HP or Asus Chromebook, for example and be fine, as long as you’re okay with an HP SPS# LCD on a Dell Chromebook which had a DP/N identifier.
You can identify if it’s LVDS or iDP from the display model number - you can usually find a datasheet, or a site which tells you which one it has. Now as far as we know we can’t say for sure and it varies wildly in many cases (Ex: HP uses LVDS on Intel, iDP on MediaTek). If you take the bezel off and remove 4 screws, that will do it for many of these Chromebooks.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
deborah mateo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 129
