Stuck a wire inside my chromebook
The other day I stuck a wire inside my chromebooks headphone jack really far in to try and clean it and then it turned off. It won’t charge on that side anymore and overheats constantly. It still turns on and works but just can only be charged on the right side. Can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
It sounds like the wire may have bridged some components which weren't supposed to make contact. I would be curious to see the internals of the actual machine, since I wouldn't expect this to occur just from bridging headphone contacts.
It's probably possible to fix, but it's difficult to know for sure without some more context. Which model of Chromebook is it? The model number should be listed on the bottom of the device.
完成的
Hi @albertofo and any one else,
You did this with the power on! That is called "asking for trouble".
Always, always turn off and unplug when doing any repair. This is an absolute must do.
完成的
I hope it wasnt a school chromebook, that wont be fun to deal with.
完成的
添加一条评论
