跳转到主内容
加入维修社区 - 创建账户
Why can't I unscrew these screws on the volume rocker of my gameboy?
Below are pictures of those screws and the screwdriver I am using to unscrew them. Can you tell me what’s wrong if I am doing something wrong here?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
I am sorry, but you seem to be using the wrong screwdriver for the job. You seem to be using a tri-wing screwdriver on a triangle head screw. You will need a screwdriver that is the correct shape. Here is the correct screwdriver: https://www.amazon.com/Silverhill-Tools-...
P.S. If you want to get a whole set of different bits, you can buy a kit, too. iFixit’s are really solid, but there are cheaper kits on Amazon you might also like. Happy to reply to any questions you may have.
这个答案有帮助吗?
得分 0
2条评论:
If you are in an extreme case unlike me, then follow Jose's answer or buy a screw extractor. If not then wrap your screwdriver with tinfoil. Thank you for reading and thank you Jose for the help.
完成的
@retrospeticus You're very welcome.
完成的
添加一条评论
添加你的答案
Fuad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 25
过去 30 天: 39
总计 355
