跳转到主内容
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
280 个问题 查看全部
Yamaha AV Receiver (DSP-A1092) don't work properly
Hi, I have a Yamaha AV Receiver, DSP-A1092 and I'm not able to find exactly what is the problem. The outputs are not working, except for the front effect (R and L). I know could be the logic board, the amp or relays.
The folder with manuals (Owner's manual and Service Manual).
If anyone helps me to figure out what it's I would be so happy, thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Hi @thatoo_apple,
Have you tried the manual test tone as described on p.14 in the service manual to see if the dac is working
完成的
Hi @jayeff,
Thanks for answering me. I already had done that, but I tested another time. Let me give you more results about the second test tone. The front effect, the rear (R and L), and the Center (D and C) are working, but none of the others. Also, I tested the (6) Front Panel VFD, (7) Factory Present, and (8) Ad Conversion data. All normal.
What do you think could be?
完成的
添加一条评论
1个答案
From a quick scan of the service manual, each set of speakers has its own protection relay and relay driver transistor. I would start looking there. It is possible that the relay drivers are not working or that they are being told NOT to trip the relay because of over current detection. Check those transistors as well (Q165,167, 170, 173,176,179, 205 and 211). See page 44ofthe service manual for the reference (lower right hand corner). The power amp for the front speakers is an IC while the other channels use discrete transistor amp circuits. These too could have a problem. Since all channels except for the front seem to be out, I would look for a missing voltage that supplies all of the discrete amp sections.
Dan
这个答案有帮助吗?
得分 0
1条评论:
Hi, Dan. Thanks for answering me. I believe this could be the solution. How can I test these parts? I have a multimeter. I'll take some pictures of the PBC and upload them here too.
完成的
添加一条评论
添加你的答案
thalisson_santos 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 140
