Yamaha AV Receiver (DSP-A1092) don't work properly
Hi, I have a Yamaha AV Receiver, DSP-A1092 and I'm not able to find exactly what is the problem. The outputs are not working, except for the front effect (R and L). I know could be the logic board, the amp or relays.
The folder with manuals (Owner's manual and Service Manual).
If anyone helps me to figure out what it's I would be so happy, thanks.
Hi @thatoo_apple,
Have you tried the manual test tone as described on p.14 in the service manual to see if the dac is working
由 jayeff 完成的
Hi @jayeff,
Thanks for answering me. I already had done that, but I tested another time. Let me give you more results about the second test tone. The front effect, the rear (R and L), and the Center (D and C) are working, but none of the others. Also, I tested the (6) Front Panel VFD, (7) Factory Present, and (8) Ad Conversion data. All normal.
What do you think could be?
由 thalisson_santos 完成的
