跳转到主内容
苹果2019年度的旗舰手机发布于9月20日,该设备配备5.8英寸OLED显示屏、三颗后置摄像头,电池续航能力大幅度的提升。为iPhone XS的后续机型。
75 个问题 查看全部
battery replacement by myself
Hi!
I bought a battery in a phonestore, yes not original apple one, made the replacement and look at what 3utools says of it :
So, the battery seems very okke….but I have to charge it each day even if the phone is off all night long and my day use is very little…What can I do for recovering the real capacities of this battery?
Update (12/08/2021)
tojaert, thanks!
Making the replacement I torn a very little bit of the black flex connecting the BMS and the motherboard, I would say 1mm long. I recovered this little part, which have become gold coloured, with a little bit of “isolier band” thinking that would make the trick… But now, after reading your message, I think probably this is the cause of the too fast discharge of the battery…Do you think like me tojaert?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hello Jacques Louis,
Looks like your new battery is ok. Corresponds to the phone driver and everything seems to be ok. Unfortunately, the fact that this phone is charging every day draws attention to something wrong. This battery with such parameters should last for about 4 days, otherwise it indicates an internal short circuit in the installation. Another matter is where the short circuit is located. A few informations would be to describe the recent suspicious cases in the life of this phone, I assume there were it a few. If you are not into microelectronics, you should use a good repair shop. Diagnosis and finding of abnormalities should not take more than a few moments in good hands and the cost should not exceed a maximum of $ 20. The cost of the repair is another matter - it depends on the location of the damage, as well as the skill and willingness of the repair shop.
However, he does not underestimate the problem. In a few weeks, the battery will begin to swell and push the screen upwards - possibly leading to a crack. Either way, you will need another new battery over time if you don't fix the fault.
这个答案有帮助吗?
得分 0
评论:
tojaert, thanks!
Look at my update
完成的
hello, it is possible. To eliminate such a variable, remove this element - the phone will for sure work normally without this element (for testing, of course. Deficiencies will have to be filled for the whole system to work properly). Take a picture of this item - you can post it here or email it - I'll tell you what it is and if you are right. email you will find in my description. Regards.
完成的
look at my answer tojeart!
完成的
添加一条评论
pictures battery :
这个答案有帮助吗?
得分 0
评论:
I don't think that's the reason for your problem. In proof of this, the technician would plug in a new battery and nothing would change. In fact, you need to connect an external power source and a multimeter to the motherboard. The numbers will show the current and prove my thesis.
my advice, take it to the workshop, someone will connect it for you and you will see yourself. The cost of such fun should not be high. In my workshop, in Warsaw, I would do such things for someone for free (if only out of curiosity), but the world is diferrent.
完成的
添加一条评论
添加你的答案
Jacques Louis de Coulon 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 52
