跳转到主内容
The Backbone One is a mobile game controller for the iPhone. It was released in October, 2020.
7 个问题 查看全部
Backbone one ribbon cable is damaged. How can I replace it.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Did you ever get this fixed?
完成的
This isn't fixable. I've taken the whole device apart and they have effectively glued the ribbon into the central "bone" of the device. You do not have access to that area unless you are willing to break through the plastic, I doubt you will cleanly separate the central bone.
完成的
Well, i'm using it for a handheld PC so I wont need the middle part.
完成的
添加一条评论
1个答案
最有帮助的答案
I had this issue with a JBL Speaker. There was some numbers on the ribbon cable itself so I tried them on the internet and had no luck.
What I ended up doing was counting the number of pins that were on the ribbon cable I then measured it in (mm).
Then for example I went in to google typed ‘6pin 250mm x 20mm ribbon cable' and one poped up so I ordered and it was the correct part and it fit the device perfect and the device powered on. It only cost me like £3 so I didn't mind the risk of ordering it for it to fit or not.
Try this your your device and let me know if it worked for you.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Erik Chavarria 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 57
总计 584
