跳转到主内容
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
170 个问题 查看全部
Can power supply fuse (F12.5A) be replaced wih a 12A fuse?
The F12.5A ceramic fuse for 700 watt ATX power supply is blown, I think it may have been because of an accidental short. I have searched widely and although different sites list the fuse, no one has one and seem to indicate that the fuse is no longer produced. Would a 12A fuse work or is that half amp a deal killer? The load would be MB, 3 HD, 1 optical drive. Video would not be a gaming one.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Yess O.5 amp lower is acceptable, make sure to test fuse by checking its continuity through a tester meter always before installing it.
这个答案有帮助吗?
得分 1
1条评论:
hadn't thought about testing the fuse - useful!
完成的
添加一条评论
最有帮助的答案
Lower is fine but NOT higher.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jim Lindemann 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 8
总计 336
