跳转到主内容
Repair and disassembly guides for projectors.
I'm having problems with my Hdmi damage
Can an HDMI port be fixed if it's damage, I've tried everything that I know, and nothing works, I'm thinking that this is the problem. I've unplug it, it didn't come on, it doesn't even show up on the settings anymore. And when I go to the settings, it says that HDMI IS OFF and yes I use it with my fire stick for a while with know problems until now.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi @leehampton,
What is the make and model number of the projector?
Have you visually inspected the HDMI port with a magnifying glass, for any damage e.g. bent pins etc?
完成的
添加一条评论
1个答案
已选择的解决方案
If it is the HDMI port yes it can be fix by buying a new port and soldering it in. This is normally not hard to do. The hardest is finding the right port configuration. If you take the unit apart it may have numbers un it or at lease you can take a picture of the HDMI port and start looking online for a replacement. Sometimes calling the Manufacture they can tell you the part number. you will need a soldering pen(or torch and small nail) and leaded solder and solder flux.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Carl Hampton 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 396
