跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
466 个问题 查看全部
NFC / Apple Pay not working after repair
Hi all,
I did a chassis replacement on an XR and this happened the last time I built my 8 plus transferring components to a new chassis. The NFC Function stops working and Apple Pay doesn’t work anymore it can’t read NFC Chips and I can’t pick anything up when using Apple Pay.
I’ve went back and made sure all screws are done I’m running out of ideas it’s really annoying if this same issue happens everytime I do this.
hope someone can help thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
What chassis did you use? And OEM donor or an aftermarket? Did you double check and make sure you transferred all of the necessary antennas?
这个答案有帮助吗?
得分 0
添加一条评论
I used a aftermarket chassis, as far as I am aware everything is exactly how it should be.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Connor Caunt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 168
