跳转到主内容
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
277 个问题 查看全部
Why can't I change my brightness?
Hi i recently replaced my Macbook pro 2017 13’ screen, everything works until i tried to change my brightness, it is stuck at full bright and i cant change it using the control centre or the touch bar, also when i go in to settings and to display the brightness settings don’t appear. So i was wondering whether i didn’t plug a cable in correctly or if there is something i need to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Sorry, you bought a new display which still needs to be calibrated. You’ll need to visit someone who has access to the needed software tools, you can thank Apple too!
这个答案有帮助吗?
得分 0
4条评论:
I didn’t think the MacBook screens needed to be calibrated or anything.
完成的
@Savage Ccjj - Sorry Apple altered things!
Get a used unit and you'll be fine!
完成的
Hi, i have the same problem and i dont know what to do, can you tell me if this sollution worked?
完成的
@karooob11 - Did you replace your display your self?
完成的
添加一条评论
Hi, i have exactly the same problem, can you tell me if you fix it please?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Savage Ccjj 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 569
