跳转到主内容
iPhone 13 mini 于 2021 年 9 月 24 日发布,它是 Apple iPhone 13 的缩小版,也是第二款的迷你 iPhone。 iPhone 13 mini 具有 5.4 英寸 OLED屏幕、A15 仿生处理器和后置双摄像头。
31 个问题 查看全部
Charging Cable For iPhone 13/13 Mini and Old iPhone SE?
I bought an iphone 13/13 mini and going to keep one of them. My current phone is an old iphone SE thats been used for many years. Battery is very bad. So when im outside, I would have my connecting charger cable and a powerbank to connect to my iphone SE to charge it if necessary. This is my current powerbank below.
The brand seem to be called Poweradd on it. But the link i post is a different brand as I can't seem to find this one anymore but should be the same.
https://www.amazon.com/Compact-5000mAh-E...
My question is, could i use my current powerbank with either of these two new iphone 13/13 mini? I assume I can with the same charging cable and 5W adapter I’m currently using with the old SE? Only difference is it wouldn’t be charging fast right? The thing is my charging cable is really bad condition so I need to buy a new one. Which of these cables work? I checked online and the usb type a to lightning cable is the one im currently using with my iphone SE? But does that mean the first link lightnight to usb won’t work?
https://www.bestbuy.com/site/dynex-3-lig...
https://www.bestbuy.com/site/dynex-3-usb...
I did buy a 20W usb c adapter for the new iphone to be used with the usb c to lightning cable that came with the new iphone 13/13 mini. Thus it would fast charge when im inside the apartment. But I want to be able to charge my new iphone 13/13 mini and my old iphone SE with my old powerbank that I carry. So will either of those two cables work? Or only the second one?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Anyone can answer this?
Which of these two charging cables will work for my purpose?
完成的
添加一条评论
2个答案
已选择的解决方案
Both of the cables you mentioned will work with the power bank.
这个答案有帮助吗?
得分 1
3条评论:
Are you positive on this? Can anyone else confirm that? So what is the difference between first and second link? Because the first link cost more so I'm surprised if this is true.
完成的
It is true! That cable is likely cheaper due to lower-quality casings, and likely is on some sort of clearance. @Donny Pauly
完成的
So the more expensive cable thus the first one would work then with my old powerbank? What happened to the response of someone mentioning only the second link or the cheaper one would work?
Now i don't see that response anymore.
完成的
添加一条评论
Yes it should work fine
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Donny Pauly 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 7
总计 859
