跳转到主内容
The Panasonic Lumix DMC-FZ1000 is a digital single-lens camera with a rotating screen, released on July 27, 2014 by Panasonic.
34 个问题 查看全部
The micro HDMI port on my Lumix FZ1000 has stopped working.
I was using an adaptor to connect the micro HDMI port of my FZ1000 to a full size HDMI cable and all worked fine. The weight of the full size cable eventually bent the adaptor, it broke, and appears to have damaged the port on the camera as several other adaptors, specified as working with a FZ1000, will not work. I have reset the camera to factory defaults but there still is no video output on the micro HDMI port. Can the micro HDMI port be replaced?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Most cell phone repair business can probably replace the broken ports. It may take a bit for the parts to come in but unless you have done electric soldering in the past than for a camera being so compact I recommend a repair shop.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Brendan Mullan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 299
