I recently replace my iPhone 7 screen and my screen doesn’t turn on.
So I recently replaced my old iPhone 7 screen since the ribbon cable snapped. And when I replaced the screen and booted it up it needed to charge. And the charging logo and everything was there so it seemed that everything was going perfect. But when I booted it up with it havin full battery I turn it on and see no apple logo and then the screen is then on for like one second. Like it flashes when I turn it on once and then doesn’t happen again unless I turn off the phone completely and then turn it on and the same thing then happens over and over again.
Update (11/18/2021)
Update (11/18/2021)
here this is what I does
Update (11/18/2021)
here’s it in slow motion
Update (11/19/2021)
but now it doesn’t work again I’m super stressed. As soon as I opened it to put the screws back where the the connection to the motherboard it happened again
21条评论
I would double check the screen connectors. It might just be a faulty conncection.
由 honakrisi 完成的
Turn it on then connect it to the iTunes or 3utool to see if it detected to computer.
Let me know the results
由 John John 完成的
@honakrisi this is my 3rd replacement screen and the first time it worked but then the cable snapped and then the 2nd one was a faulty and now i bought this again on fixez.com idk what to do really. i'll keep you guys updated
由 Lacky KingChuck 完成的
I know but the real thing I want to know if it detect by the iTunes or 3utool.but if this is hard for you try this only if you know your battery having some charge...turn on your phone while plugging charger then leave it for two minutes then unplug the charge then plug it back...to know if you can feel vibration and sound
由 John John 完成的
@johnkangta I feel a vibration and i hear a noise but on itunes and 3utools it does not recognize it
显示更多的16条评论
