跳转到主内容
Repair information for standalone freezers.
192 个问题 查看全部
AEG integrated fridge freezer - freezer not freezing!
Hi, My 3 year old integrated fridge freezer (AEG) has a freezer issue, its not getting cold anymore unless I activate the frostmatic function, this gets it to about -8 but as soon as it clicks off frostmatic it warms up again to 1 deg. opened it up behind the drawers, fan is spinning and no ice build up. HELP!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This is a total SWAG. The unit has 2 cooling systems, so the refer is functioning. The freezer cooling system is functioning since the Frostmatic is cooling down below set value. Therefore, the problem must be in the normal freezer temp control. Either it is set too high or it is not functioning properly because the sensor or the control circuit is defective. Which one it is u will have to determine with troubleshooting and elimination.
这个答案有帮助吗?
得分 0
4条评论:
My mistake, frost attic is not working, as I have emptied freezer and monitored temp it is now 17deg and not cooling at all.
fridge part works fine
完成的
OK, then the problem is with the freezer system. That includes the compressor, control board and temp sensor/control. Start by observing the compressor if it is running. Make sure u are looking at the freezer compressor. Then verify that the temp control is calling for the compressor to run. then look at the control board and verify there are no suspect capacitors. It could also be a loss of refrigerant which is not a DIY fix. This is all technical and may require a service call if u do not understand.
完成的
Hi Craig, did you manage to fix it mate. I have the same problem on the same fridge/freezer.
完成的
Exactly the same issue with ours, freezer stopped cooling at 3 years old in September 2023 (after the warranty was out, bit suspicious?!). Did you ever fix yours? AEG charge to come out and look is £160 up front and 1/2 back if they can’t fix it… Thanks for any help/advice, Lauren
完成的
添加一条评论
添加你的答案
Craig Mckenzie 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 24
总计 429
