跳转到主内容
Repair information for standalone freezers.
192 个问题 查看全部
upright freezer suddenly stopped cooling after 1 year.
My Frigidaire Model No: FFFH20F3VW0 upright freezer suddenly stopped cooling after 1 year. The compressor is running at proper amperage. The condenser fan’s bearings seem fine. Can I enter a test mode to check condenser fan somehow?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi,
According to this link the wiring diagram for the freezer is A14353601 (see bottom of sheet for wiring diagram number, the service sheet number i.e. A14365701 is at the top of the sheet.
This shows how to enter the service mode for the freezer.
If the condenser fan is OK you need to check if the evaporator unit inside the compartment behind a panel is getting icy cold and that the DC evaporator fan is operating. The evaporator fan is used to drag air across the icy cold evap unit and blow it throughout the compartment to cool it down the set temp. The fan will stop when the door is opened and start again when the door is shut.
Here’s a link to the parts for the freezer, showing the evap fan (#28 cabinet parts diagram) and the switch (#45 cabinet parts diagram).
If the evap fan is iced up then there is a defrost problem. This could be caused by a faulty defrost heater, faulty defrost thermostat, blocked drain from under evap unit to the evap pan under the freezer or a faulty control board. The service sheet show how to manually test the defrost.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
HoferI Isaiah 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 362
