New battery apparently failed
I replaced my iPhone 6s battery after ordering a new one from ifixit.com. After following instructions to the T and a good install with no problems I plugged my phone in and charged as per the instructions. After removing the phone from the charger it was once again dead after 4-5 hours with no use and will not charge again. Had I have known that it would react the same way as the old battery I would have immediately backed it up on my computer! I was waiting to sync it as instructed before backing up.
Please Help!!!
4条评论
Yes it did show charging after being plugged in. As it discharged over the 4-5 hour period it became warm to the touch as it was getting close to 0%.
I plugged it back in to charge and nothing
由 Rex Jackson 完成的
You may have just gotten unlucky and it was a battery that bearly passed QA but the heat killed it in some way
由 stressmaster 完成的
@Rex Jackson yeah contact the battery seller they should send you another one free as it failed on first use
由 stressmaster 完成的
@Rex Jackson If you want to try a bump charge you can follow what I said in the following comment. It explains a little about how lithium batteries work and how to recover a battery that will not charge. usually with about a 80% ish success rate.
Also when you get the replacement battery put it in WITHOUT turning the phone on. charge it while the phone is off and using a volt meter check it before charge, after charge, & after a couple hours. If you lose more than 0.2v from the full charge of about 3.8v-4.2v(depends upon battery controller and capacity) while the phone is off and no longer plugged into charger but connect to the phone than it may be a faulty which you than may need to reflow a solder point somewhere or replace a resistor. just look for corrosion.
由 stressmaster 完成的
