跳转到主内容
Popular clothes dryer series by Kenmore.
60 个问题 查看全部
I replaced my dryer belt but still not turning.
I replaced the dryer belt, but when I started the dryer up again it heats (very hot, almost smelled burnt) but drum doesn’t turn. I noticed the dryer belt was very tight to put on, is it possible the size is too small, could that prevent the turning?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
double check the belt model and installation
完成的
添加一条评论
1个答案
If the belt is specified to fit the dryer it should be the right size unless they gave u the wrong belt.
Is the motor turning? Did the drum turn b4 u put the belt on - IE not jammed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sarah Fosnaugh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 15
总计 177
