跳转到主内容
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
299 个问题 查看全部
Why Does My iMac Screen Flicker or Just Not Work?
I have an early 2009 21.5 inch iMac. The vast majority of the time, my iMac screen doesn’t work. I power up the iMac and the screen flickers once and then just turns off, but the machine itself runs fine, and there is video output to an external display. The problem started a few years ago and it started as just some minor backlight flickering, but eventually the screen stopped working completely. I have gone through all the basic troubleshooting steps (I.e. reset the NVRAM and PRAM) and none of them work. The screen only works when I leave it sitting for a long time (sometimes as long as a month), and then it powers up fine, but after about 15 minutes of use, the screen starts flickering and then just turns off completely. Any and all help would be much appreciated. :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You likely have one of two possible issues
  • The LED Driver Board has failed
  • The display backlight board connector has failed
You need to open the system and check your voltages.
这个答案有帮助吗?
得分 0
4条评论:
How do I check the voltages?
完成的
@Tobin Redekop - Using a DVM
I think your best bet here is to find a local shop who can help you as this can be dangerous! 120 voltage is nothing to mess with without a good understanding of basic electronics and electricity.
完成的
@danj I didn't know shoes were powered by electricity :P.
完成的
@nick - Funny!
完成的
添加一条评论
添加你的答案
Tobin Redekop 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 60
