MacBook Pro 2018 won't turn on
Hi,
This is my first time dealing with such issues and having no clue whatsoever. At first my Macbook turned off while watching some video and it won't turn on even after trying all the possible troubleshooting methods out there. Even tried troubleshooting with an apple executive but din't turn on. So, I went to the Apple service centre and they said as my Macbook was out of warranty they'll diagnose the device which will cost be 2500 INR (25$) to which I agreed. And then I got a call from them that there's some issue with the motherboard and it'll cost me 85k INR (1150$) for the repair and the problem is they didn't mention what was the exact issue with the motherboard. I told them I don't want to get the repair done as I found it to be too expensive and didn't wanted to shell out that kind of money. Now I'm able to get my Macbook into DFU mode but I'm not able to restore it as the second device is a Macbook Pro 13" which I'm not sure will work. So my question here is this:
Can a faulty motherboard laptop go into DFU mode? Also shouldn't Apple care centre tell me about the exact problem the Macbook is having?
Some more info: The dead Macbook was on Monterey beta and I'm not sure if that's the reason it's not restoring on the Apple configurator 2.
5条评论
Greetings friend, I have exactly the same problem as you, my mac can be put in dfu mode but I can't reset it, I would like to know if you found a solution?
由 Nicojoelito Reyes 完成的
some solution please
由 El haddad Mohammed 完成的
@El haddad Mohammed - Did you follow the answer offered?
由 Dan 完成的
Yes I do but doesn't t exit dru mode
@elhaddadmo48483 - Sorry to hear that, time to visit an Apple Store.
由 Dan 完成的
