How to install windows on iMac's second SSD?
just installed second 250gb SSD on my iMac to install windows here. tried different ways and programs from internet but nothing helps . BootCamp can’t recognize second SSD, only shows main SSD.
BootCamp will only work off a single drive/partition where both macOS and Windows OS’s sit. You can use a second drive (or multiples) as data drives for either OS (or even other OS’s).
Your only means to run dual OS is full isolation (requiring a reboot to switch) without using a VM product. A Virtual Machine (VM) can do what you want but its much harder to setup with multiple drives and some products are not able to do it.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 806
Can you see both drives after booting into MacOS and going into Disk Utility?
由 Andrew S 完成的
Yes Disk Utility shows both SSD. but BootCamp shows only main SSD. just talked with apple support and said that bootcamp will not allow install windows on second drive. I bought SSD, bought Sata cable for iMac and now discovered that can't install windows here, what the Hel l :|
由 Ramaz 完成的
