跳转到主内容
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
566 个问题 查看全部
Will my iMac work without a blade SSD?
I have a Samsung PCIe SSD 12x16 pin 2380 Blade that I need to erase and reformat but i’m getting corruption errors and not able to find an appropriate enclosure to have it reformatted externally. I plan to not use the slot and leave it empty and just add on this SSD as my only storage device for files, OS etc. My question is will my iMac still work without a SSD Blade in the PCI slot and only the SSD in place of my current HDD ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Sure you can take the 8.0 GT/s PCIe/NVMe blade SSD out and only use the SATA III (6.0 Gb/s) port to hold a replacement SSD instead of your current HDD.
Just keep in mind the PCIe port is much faster than the SATA
If you want an external case this should work OWC Envoy Pro
If you want to maximize your PCIe/NVMe port checkout these SSD’s OWC Aura Pro X2 SSD Even going with a 489 GB SSD might make sense depending on your workflow. Here I would use the blade SSD as your boot drive with your apps, leaving the rest of the drive empty! Then using the SATA port to hold either a HDD or SSD as your data drive (not using Apples FusionDrive setup) this gives you the maximum performance the system can offer.
OWC Aura Pro X2 SSD图片
产品
OWC Aura Pro X2 SSD
$99.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andrew Phillips 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 188
