跳转到主内容
The current line of iPod touch comprises seven (7) different generations.
2571 个问题 查看全部
iPod Touch 6th Generation - Does not charge, yet detects power in.
I’ve recently figured out the magical method to get my iPod to start existing again; it took some power right to the battery terminals (for reference, the pinout seems to be the following: -, Battery Sense, +) to do this, but it’s not stone-dead now.
Now the issue that comes forth is the following; when plugging the iPod in with a known-working power cable and power adaptor, I can not get the iPod to charge. It will only show the “please connect to power” symbol on screen, and nothing more. What could be the issue? Battery sense, or just the board in general?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
评论:
Was the battery having any problems before this?
Have you tried a different charger?
If it previously charged connecting directly to the battery terminals, I would assume it’s the board, but I just want to verify these things first.
完成的
I've tried a different charger already, and the battery wouldn't accept a charge through the Lightning port already... would I be in for a board replacement?
完成的
添加一条评论
2个回答
已选择的解决方案
Update: Applying external power to the battery terminals seems to have worked
For reference, the pinout is as follows, from the left side of the iPod: [- T +]
The iPod works now, however it’s slightly picky with cables. I can live with that, so I guess I solved it!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
@devzero I would consider a new battery first to see if that's the problem. If it's not, it could just be the lighting connector. I would troubleshoot these fairly easy/inexpensive parts first before jumping to the board replacement.
这个答案有帮助吗?
得分 1
评论:
Alright, perfect; I'll try a new battery when I can get around to it.
完成的
Awesome, reach out if you have any questions. Here is a link to the battery for your model.
iPod touch (6th and 7th Gen) Battery
完成的
添加一条评论
添加你的答案
Kaleb White 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 25
