跳转到主内容
My PC doesn't display the bios screen and boots straight into Windows
My PC will not boot into BIOS at all. I did a CMOS reset. I went to Advanced Settings to UEFI. I have tried everything. Tried booting without HDD’s, nothing. I don’t know if its a CPU issue or a Motherboard issue or even a Monitor issue. I cant get into my BIOS at all. I personally don't think my PC is skipping the BIOS but it's just not coming up on my display because as soon as I boot I see a brief “input not supported” message appear on my monitor it then goes away and I boot into windows like normal. I am running onboard graphics for now and I have seen people suggest that could be the problem but have found no fix can someone please help me.
I have been looking for a fix for this for weeks and I have no clue what to do. I may just let my PC rest and see if it fixes itself.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
4条评论
Hi @jchap2506 ,
What is the make and model number of the PC or the motherboard if a custom build?
完成的
Hello the make of my motherboard is a b450 aorus elite.
完成的
did all things but have same problem. not found a solution.
I tried with delete key, but in screen is black and monitor is blink with blue button. after press ctrl+Alt+Del its again reeboot and straight screen to windows. not showing Boot Menu .. 😰
完成的
Have you tried all the function keys?
完成的
添加一条评论
5个答案
最有帮助的答案
Hi @jchap2506
Have you tried disabling fast startup and check if you can get into BIOS with a display, as you didn't mention doing this? Press the Del key to enter BIOS during POST i.e. after Startup but before Windows boots
Check if you have the latest motherboard drivers installed i.e. BIOS and chipset. The video drivers for BIOS are stored in BIOS so perhaps there is a problem there.
Here are links for b450 aorus elite motherboard Rev (1.x) and Ver.2 (1.x). They are different so if you decide to update make sure that you get the correct ones.
Also do one at a time and check before doing the second, perhaps the chipset drivers first.
这个答案有帮助吗?
得分 1
添加一条评论
I can’t really help too much without being there in person but there are some things you can try:
  • Try using a different keyboard or mouse to enter the BIOS.
  • Make sure you are pressing the correct key to enter into the BIOS.
  • Check the Manuel, if you don’t have it; most manufacturers’ websites will have the manual.
  • Try another monitor; maybe that will help.
  • If all else fails. Contact your manufacturers’ support center.
I’m afraid all I can offer is those tips.
这个答案有帮助吗?
得分 0
4条评论:
Hello. Thanks but I don't have any way to try to enter the BIOS due to the display been blank with a display not supported message showing.
完成的
Then try another display, unless you can’t.
完成的
I have and It has worked on some displays which is why I think it is to do with either my current display or something wrong with my APU.
完成的
Then it appears to be that your display is not able to display the BIOS. So the problem is with your display. Especially if it works on other displays. Try updating the monitor or installing the correct drivers and see if that helps.
完成的
添加一条评论
Probably the GOP on a graphics card
这个答案有帮助吗?
得分 0
添加一条评论
the key to hit to get into bios is different for different MFG. It definitely is not CRTL-ALT-DEL.
Try ESC, F1, or DEL.
这个答案有帮助吗?
得分 0
添加一条评论
Had this issue with my acer ka242y monitor
Seems that my bios resolution is not supported by my monitor. Had to use a different monitor to see motherboards logo and access my bios
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jacob Chapman 将永远感激不已
浏览统计数据:
过去 24 小时: 66
过去 7 天: 380
过去 30 天: 1,842
总计 15,378
