跳转到主内容
发布于2019年9月20日,这是苹果在2019年发布的最大且最贵的智能手机。它带有6.5英寸的OLED显示屏、三摄镜头以及大幅提升的电池续航。它继承了iPhone XS Max产品线。
77 个问题 查看全部
CPB Heating Mat for iPhone 11 pro max screen removal
I’ve got a CPB mat and it worked like a charm on several iPad projects.
So i’m having bit of an issue opening the iPhone 11 pro max using the iopener, no luck.
The CPB mat has phone mode so what is the recommended temperature (in Celsius) should I use and how long should i set it on the mat?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个回答
For iPhones, I always uses 80 C, but I work with people who use 99. It really depends on how long you want to leave the phone on the mat. If you use a lower temperature, you can leave it on for longer without damaging any internal components with the heat, but higher temperatures give you more time to work with after you take it off the mat. It’s up to personal preference, but 80 C is close to the minimum. You may be able to get away with 70, but you’d risk damaging the internals by having to leave it on the heat for so long.
这个答案有帮助吗?
得分 0
评论:
Thanks for your response. I've used 60c on the mat, left it on for a few moments then the mat shut down by itself. The screen did opened.
完成的
添加一条评论
添加你的答案
Gabriel Rodriguez 将永远感激不已
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 8
总计 18
