跳转到主内容
加入维修社区 - 创建账户
发布于2012年10月23日。酷睿i5或酷睿i7处理器。配备Apple Fusion Drive.
What's the maximum supported CPU?
So I’m now the happy owner of a mac mini with an actually physically broken CPU, and I was curious what was the maximum CPU that would work in it? Any unsupported higher performance ones? Or just the one Apple put in? Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
To start things here be aware the Mini’s use a soldered CPU chip unlike 27” iMac’s (and only some 21.5” iMacs).
So you’ll need to replace the logic board assembly to properly repair this system. Mac mini Late 2012 Logic Board Replacement
As far as what are your options you are limited to what Apple used
  • 2.5 GHz Core i5 (I5-3210M)
  • 2.3 GHz Core i7 (I7-3615QM)
  • 2.6 GHz Core i7 (I7-3720QM)
So why can’t I solder a new CPU chip: Given the number of solder pads (BGA) involved here you really need a proper chip rework station to preheat the logic board and lift the old chip off and then the reverse properly heating the chip and board as one of the killers is solder pad shear when the chip and logic board shrink at different rates causing the joint to fail. This gear is not cheap and there is an art to it as well. Unless you’re working with lots of boards its not worth it.
这个答案有帮助吗?
得分 1
1条评论:
I know about BGA rework stations, but I thought it could be a fun experiment anyway, thanks for your help!
完成的
添加一条评论
添加你的答案
Nar001 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 17
总计 1,107
