跳转到主内容
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 个问题 查看全部
After battery replacement Camera won't work
So after replacing the battery successfully everything works fine except the Camera which won’t even open. Although the battery regalement never involved touching the camera connection etc and all looks ok, the Camera won’t open. Very frustrating and puzzling.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Yes it was working fine before as far as I know.
完成的
Have you try to restore device, maybe this help
完成的
添加一条评论
1个答案
Maybe you need a new camera module, before you replaced the battery was the camera working oké?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Guy Manchester 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 43
