Power button works as long as I don't shutdown+only if left on Sleep.
This is a weird one!
After replacing the SSD with an Aura Pro and getting it correctly recognized, the MBP works continuously but ONLY if left on sleep when not in use. If I shut down normally I can’t use the power button to startup again. For that reason I can only use this p/t.
I need to open the Mac back up each time I want to use it , unplug the battery connector, unscrew & re-insert the SSD, put the battery connector back in, screw the back down again and THEN it’s ready to go again but only (as described above) for a single (extended) session. Restart works OK but if I shutdown and then use the power button to start up, nothing. it’s dead!
Is this something as simple as the power button/MagSafe needing attention/repair?
Update (10/07/2021)
Hello Dan. I’ve added Coconut Battery to my Mac and here are the results:
Update (10/08/2021)
Before installing another battery tomorrow when I’ve got more time, I’ve tested both the battery and the sensors using Techtool.
Here are the results of the Sensors test.
and for the Battery
I’d be tempted to give more weight to these tests than the Apple diagnostic, but evidence is evidence. After installing the other battery I’ll let you know what happens. cheers N
3条评论
@noirguy - Well, your battery looks OK from CoconutBattery so from a power and temp sensor output from within SMC which is via the onboard micro-controller I don't see anything out of place.
But the fact diagnostics fired off a PPT004 error we either have something else that's out of place within the micro-controller data feed to the SMC or your systems logic board SMC logic has a problem.
At this point I would just reach over my desk and plug in a spare known good battery to see if that isolated the issue. But clearly you don't have a spare do you?
If not, this will require a deeper inspection of the logic boards back side which is where the SMC chip is located. But thats me! I know what to look for.
For you I'm thinking this is a bit much, I would try to find someone with deeper micro-electronics skills and access to the schematics and board views to dive into why the logic is messed up.
由 Dan 完成的
thanks for all the advice Dan.
fortunately re: a new battery, as luck would have it, I do have a spare battery. the Mac we're talking about is comprised 50% my previously owned Mac (just the Retina screen) and 50% (everything else) c/o someone on Ebay who had a perfectly functioning Mac but whose daughter had accidentally thrown a ball at the Retina screen, damaging it.
I'll fit the fairly new battery I still have from the previous body and also try running Tech Tool Pro to see if I can isolate the problem.
thanks again.
由 NickL 完成的
@noirguy - OK so this could be a parts mis-match issue!
You do need to be careful as Apple loves modifying things just enough to hinder things from working properly.
Are you moving parts between exact same models? Refer to EveryMac - Look up to validate the ID Strings of each system as an example MacBookPro12,1 for the Early 2015 13" model.
由 Dan 完成的
