跳转到主内容
Repair guides and support for all types of batteries.
74 个问题 查看全部
Anker PowerCore III Elite 26k 87w not working!
Hi,
My power bank is not charging my devices. If I press the single button it has, no lights turn on. But, as soon as start charging the power bank, all lights turn on telling me that the power bank is fully charged. There are no screws in the power bank, and I am not sure how to take it apart to see if something is loose or to check if any component has a short! Does anyone know how to fix this or knows how to take it apart?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
8条评论
got the same problem, did you solved yours?
完成的
I have the same problem, did you solve yours?
完成的
Not really. I hear a clicking sound in the inside when charging. But have not yet tried to open it up.
完成的
Same here
There is a clicking sound. I did not open yet, as I do not know exactly what to do after that. I guess we are not the only ones. haven't been able to reach a person at Anker yet
完成的
@Paz Tichover there might be a coil that is clicking but there really is not much in this power bank. All you have are 8 18650 cells and the battery controller board. We really would need to see the board to determine what may be clicking.
完成的
显示更多的3条评论
添加一条评论
1个答案
最有帮助的答案
From my previous experience in power banks, they're not easy to open and opening will often destroy the casing of the power bank(it's probably better just to buy a new power bank) .
I would push a spudger or similar into the gap between the top and bottom casing of the power bank, then try to push a pick in the gap to separate the 2 parts.
Keep in mind that puncturing Lithium ion batteries can cause toxic fumes, fire, and other physical harm.
这个答案有帮助吗?
得分 2
1条评论:
es gibt einen Beitrag bei Reddit:
https://www.reddit.com/user/Metaphesis/c...
完成的
添加一条评论
添加你的答案
Jos 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 31
过去 30 天: 109
总计 3,875
