跳转到主内容
The Bose Wave Radio AWR1-1W, also known as the Bose Wave Radio I, was released in 1993. A countertop AM/FM radio system with a high performance stereo tuner and two independent alarms.
37 个问题 查看全部
My Bose Wave Radio makes distorted humming when plugged in
This question was asked already but maybe I have more luck than the previous person. When I plug in the Wave Radio it makes a distored noise. I assume there is a electrical issue. Is it possible to save it from the trash?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
@rahhh can you post an audio file so we can hear what it sounds like? You will most likely have to take it apart, so post some good pictures of your circuit boards etc. That way we can see what you see.
在已经存在的问题里加入图片
Bose Wave Radio AWR1-1W Repair
Failed electrolytic capacitors are a possibility but one cannot rule out bad audio IC's on the amplifier circuitry.
完成的
添加一条评论
1个答案
最有帮助的答案
Can you open the radio and check for any leaky or bulged capacitors? I have attached a picture below for reference.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
r z 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 35
总计 549
