跳转到主内容
Compact digital camera with built-in flash with 10.0 Megapixel, 10x Optical Zoom and Image Stabilizer System. Disassembling requires the use of certain equipment.
19 个问题 查看全部
Camera Memory card error
I have an Imagemate SanDisk 64 GB . Camera is showing memory card error and flash will not fire. How can I fix this? I have tried different card with smaller GB, to no avail.
Sincerely, LuWanna
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
well i do know this camera will not accept 64gb sd card (I have one) the most is 32gb are you using a adapter for micro sd? I had the same problem and what fixed it was using a different adapter try another sd card if you have one under 64gb
这个答案有帮助吗?
得分 1
添加一条评论
Thank you so much! I did not know this and I will go to a 32gb. Yes I am using an adapter. Oh MY Gosh!!! I just found one in my desk :) Now my camera works, I have not been able to use my camera for well over a year now. I had a problem with batteries not working and discovered that there is also a CR1220 that goes in it. Then it was the SD card. My camera has always been an extension of my arm, I love it so much! Thank you again!
Sincerely, LuWanna
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
luwannass 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 40
总计 975
