Nintendo 2DS XL won't turn on without being connected to charger.
2DS XL wont turn on without the charger. It could turn on before I replaced the screen. Now it wont turn on for some reason. Was hoping if there's some sort of fix.
Hi,
That typically means that the battery is completely shot. The system basically sees the device with no battery attached. That’s why it will die immediately if you unplug it. I would recommend replacing the battery.
Jason
这个答案有帮助吗?
Hi, I replaced the battery with a spare one from another 2ds and it didn't work. Both batteries worked on the other 2ds tho.
At that point, I would start thinking it’s a motherboard issue.
Omg this happened to me years ago but I'm in electrical engineering school now and can actually fix it so imma give it a go
这个答案有帮助吗?
Nice, but I fixed it long time ago. It was the fuse close to the battery. Changed it and it worked again.
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 210
Can you use a multimeter to check the voltage of the battery?
由 Andrew S 完成的
@andrewsawesome No, but the battery works. Thought it was the battery so I replaced it with a spare one from another 2ds since they were the same and it didn't work. Both batteries worked on the 2ds tho.
由 Asura Destroyer 完成的
check connections to the battery on the gameboy side of things. if u have a multimeter that would be the best way.
由 Logixal 完成的
