跳转到主内容
The Nokia 5130 XpressMusic is one of Nokia's mobile phones in the series of XpressMusic. It was released in January 2009 and discontinued in 2011.
26 个问题 查看全部
'charger is not supported' message comes
when i am connecting the charger to the phone there is "charger is not supported" message comes..then i had tried with different charger.but the same message comes and my phone is not being charged.plz any one help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
4个答案
最有帮助的答案
meghna gayen, check on here seems like a common problem. Looks like changing the 47k resistor works for most people. Of course make sure that you have the charger for your phone...;-)
这个答案有帮助吗?
得分 1
添加一条评论
Nokia 5130 charging not supported.
Solution is here now
这个答案有帮助吗?
得分 1
1条评论:
Mehak Mahoo, same solution as above.....;-)
完成的
添加一条评论
Change the battery
这个答案有帮助吗?
得分 0
添加一条评论
Change the battery if you repair you battery after some time this problem come again and again so kindly change your battery
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
meghna gayen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,320
