跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1197 个问题 查看全部
Can I upgrade to a multi touch trackpad
can i upgrade my mid 2009 macbook to have a multitouch trackpad by replacing the keyboard/trackpad panel with a panel from a 2010 mac.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
已选择的解决方案
The short answer is no. A 2009 macbook (non-unibody) lacks the necessary software components to support multitouch.
That being said, it may be possible to hack this capability, but not without the aid of some external files.
这个答案有帮助吗?
得分 2
1条评论:
that is why Apple sucks so hard.
完成的
添加一条评论
You can't do it that way, but there is a way.
You can fit a trackpad from the early 2008 non unibody MBP to a white macbook non-unibody. But it's messy work, and the trackpad is silver.
There's a post on macrumors about it:
http://forums.macrumors.com/showthread.p...
这个答案有帮助吗?
得分 1
1条评论:
Hi I know this is quite out of date but can i upgrade my macbook pro E 2008 to a newer pad type?
完成的
添加一条评论
yes it works just fine upgrade to 10.7.5.
这个答案有帮助吗?
得分 1
添加一条评论
Buy a separate multi-touch trackpad or one of those multi-touch mice apple has. I keep messing up that name so I won't type it :D
If you have the skills one could simply try to use the separate trackpad using the usb connection and mount it where the old trackpad was, obviously connecting it from the inside. Not sure how one would go about that, but it's too much of a hassle if you ask me :D
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 2,625
