跳转到主内容
The Ford Fiesta is a subcompact car (B-segment in Europe) manufactured by the Ford Motor Company since 1976.
16 个问题 查看全部
My lock fob has suddenly stopped working on my Ford Fiesta 2012 plate
My key fob has stopped working on my fiesta. I can use the key to manually lock and unlock the doors.
can’t change battery as it’s a sealed unit
Update (09/02/2021)
her is a picture of my fob
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @joys2121 ,
Here’s a video that shows how to open your key fob to replace the battery.
The battery model used is a CR2032. It is a common battery available most everywhere e.g. supermarkets.
Note: Ensure that you insert the new battery the same way as the original. There is a +ve symbol marked on the battery so that you know which way it goes into the battery holder.
这个答案有帮助吗?
得分 1
1条评论:
Thank you so much for your help changed battery easily with the help of you tube had to re program after changing the battery but google helped with that
完成的
添加一条评论
最有帮助的答案
Hi @joyspurrier, can you attach a photo of the key fob? (Click here for directions on how to add photos to your post.)
Even with the “sealed” devices you can usually get into them with a spudger (or a guitar pick, credit card, or flat head screwdriver). Once you’re in, you should be able to swap out the battery. This guide has a quick video example of using the key to open their fob.
Hope this helps!
iFixit图片
指南
在已经存在的问题里加入图片
难度:
非常容易
2 - 5 minutes
2009-2015 Toyota Prius 车遥控钥匙图片
指南
2009-2015 丰田 Prius遥控钥匙更换
难度:
非常容易
2 minutes
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
joy s 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 790
