跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
383 个问题 查看全部
MacBook air 2017 not turning on.
My Mac is not turning on. When I switch on the laptop the fan rotates for 2 seconds and then stops. Nothing else happens. I have tried removing the battery and run it on adapter. But the same result.
Also when battery is connected, there is no light on the adapter. But when battery is removed, the adapter light is on.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Try disconnecting the trackpad flex cable from the main logic board (shown in Step 23 of this guide). With the cable and battery disconnected and the bottom plate removed, open the display and set the machine on its side with the MagSafe 2 port facing upward. Then connect the MagSafe charger and press the power button. If it’s able to power on the issue may be due to a failing trackpad flex cable or a failing trackpad.
If that doesn’t help, you’ll need to do some further troubleshooting with the I/O board and the logic board as the point of failure probably involves one of those two components. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tuhin chakrabortty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 66
