跳转到主内容
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
123 个问题 查看全部
Post-battery replacement, battery no longer charging
Replaced a swollen battery with iFixit’s kit. Was (and continue to be) delighted by the experience. After a little over two weeks of good functionality, the watch no longer charges past 3-4%. It registers once docked, and still communicates with the iPhone — but is no longer a practical device.
Any advice?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Concidering that the battery was working for a while after the installation, there may be a defect with the battery.
There is also a good chance that the battery is not connected properly. Possibly the data line of the battery which would cause odd issues as you’re describing.
If you still have the old battery, it may still be able to charge a bit. You could use it to confirm that the new battery is at fault if it charges more then 4%. I would try to reconnect the new battery first.
If none of those seems to work, there is a chance of damaged motherboard components, or partial damage to the charging flex cable. These are less likely since the watch was working for at least 2 weeks after installation.
I hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
fjd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 15
总计 172
