跳转到主内容
Samsung的旗舰手机,Galaxy S8,发布于2017年4月。
304 个问题 查看全部
Won't turn on or charge, have replaced battery and charging board
What next? If I replace the motherboard is that likely to fix it? I am new to phone repair, so I can't think that it's anything else, but I wanted to ask people with more experience first!
Background info: I got the replacement battery from ifixit (along with the excellent tools) and the charging daughterboard from ‘therepairshop' on ebay. Both went in without a problem, but the symptoms remain the same as they did when we discovered the problem one morning - the phone is completely dead. Won't turn on, apparently won't charge - no LED indicator, and leaving it plugged in overnight does nothing. Also, before I started the repair process I followed Samsung's triage process for resets, different chargers etc.
Hope that's enough background :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I would suggest ordering a USB amp meter. This will give much needed information.
Your current should be at about 0.12amp ish with fluctuations with the battery disconected. And anywhere between 0.45 to 1.2-1.6amp with the battery connected depending on the battery voltage.
A steady eading of 0.45 amp with the battery disconecting is often a sign of a short or failed IC.
If so the motherboard may need to be repaired. Replacing it would also be an option if you don’t want to repair the circuit board.
I’ve seen a fair bit of galaxy s8, and s7 with failed power IC. And usually they read 0.45amp with the battery disconected.
这个答案有帮助吗?
得分 0
1条评论:
How can the amp meter help when the new battery is dead and it won’t take a charge?
完成的
添加一条评论
This post is 2 years old, but if someone have the same problem, here is the solution I found.
I had the same problem on my Samsung Galaxy A51, I changed the battery and the charging port but my phone still wasn't charging. I found that in my case the problem came from the flex cable connecting the charging port to the motherboard (the big orange one with the phone model written on it). I changed it and my phone is now charging normally!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tom Scott 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 17
总计 158
