跳转到主内容
加入维修社区 - 创建账户
Trackpad & Keyboard not working
Hello,
My Macbook Pro’s Keyboard and trackpad simply stop working at random moments while in use. Bluetooth keyboard and trackpad still work fine, but this isn’t a fix.
Resetting PRAM doesn’t work.
Restarting the computer repeats the process, but is a temporary fix to the problem.
This also means that the issue isn’t the connection, so I am unconvinced replacing the parts would work.
Are there any other troubleshooting options to figure out why the system is failing? Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Enable the keyboard viewer to see if the keys are firing.
At this point it sounds like you need a new keyboard. Spillage liquid and solids could have messed you up. Time to replace the keyboard or the uppercase assembly.
This series has a much more serviceable keyboard as its screwed in! Sadly its a ton of screws. But the keyboard is quite cheap MacBook Pro Unibody (A1278) Keyboard here’s the guide you’ll need to follow to get to it MacBook Pro 13" Unibody Late 2011 Upper Case Replacement as well as a new trackpad MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a scratched or malfunctioning trackpad in your Mid 2009 to Mid 2012 13” Unibody MacBook Pro model A1278 laptop. Part #922-9063, 922-9525, 922-9773.图片
产品
$54.99
Replace a damaged, dirty, corroded, or malfunctioning keyboard and power button switch compatible with a mid 2009 to mid 2012 A1278 model 13" MacBook Pro Unibody laptop.图片
产品
$19.99
这个答案有帮助吗?
得分 0
5条评论:
In truth, it was a last resort for me to replace the parts, considering they were working fine before I replaced the logic board, and still work fine if I restart the computer.
But it certainly won't hurt to try.
Thanks for the pointer. I'll be back if the issue persists. Thanks!
完成的
I'm back.
The keyboard that was sent turned out to be defective. Random keys would type on their own in the middle of me typing, most noticeably the equals sign and the spacebar.
Having reset pram on that keyboard, and also switched back to this current one, I can confirm that the keyboard that was delivered was the problem.
I am rather frustrated at this news as I had spent hours disassembling and reassembling my computer suspecting that there was some other issue or need of cleaning that would arise to fix it, to no avail.
完成的
@realhittman - So you are now working with a fresh keyboard?
完成的
@danj It is not. I placed my old keyboard back in, it's the one i am using now.
Frankly, I would rather endure periodic computer freezes than constantly activating random keys.
完成的
@realhittman - Sorry to hear about your bad luck. Maybe its worth looking at getting an uppercase assembly while a bit more expensive its a lot easier to replace MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case $80 USD is not bad (Grade-B)
完成的
添加一条评论
添加你的答案
Anthony Hitt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 141
