跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone won't charge after battery replacement (red battery icon)
I just bought an new battery but it wouldn't charge after the replacement. I've tried replacing my old battery and it works just fine. The new battery only shows the red battery icon after plugging the charging cable, and won't turn on the phone.I tried measure the voltage but it's normal (3.82v), is there any solution for this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If the original battery still lets the phone power up, then it seems like you received a faulty battery. Contact whoever you got the battery from and see if you can get a replacement.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for replying, I had contacted the seller, still waiting for the reply.
My phone just turned on after 1 night of charging, but it suddenly turned off after I entered my password (2% of battery).
I also want to know the reason why does it charging so slow. Voltage of the battery seems normal( stable 3.82V), and the charging cable, adapter works fine either, so could it be the battery IC failure?
完成的
@linsyun Faulty batteries can do all sorts of weird things, I would guess that is related.
完成的
添加一条评论
添加你的答案
syun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 28
