跳转到主内容
Xbox Series X 是微软公司次时代4K游戏主机。2020年11月10日,Xbox Series X与其配套主机Xbox Series S一起发布。
66 个问题 查看全部
Xbox series x fan clicking noise
So sometimes the fan of my Xbox is emitting some sort of clicking sound as if it is touching something although it isn't. I'm assuming it's some sort of ball bearing issue. Any ideas what it might be? And if it's the bearings: is it ok to just leave it if the noise isn't bothering me?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Im getting the same issue on my series x consolw aswell
完成的
添加一条评论
3个答案
Try taking it apart and check if the bearing is broken or something is wrong with the fan.
这个答案有帮助吗?
得分 0
添加一条评论
I managed to resolve this, no need to open the console.
Stand xbox vertically and with front facing you
Through the vent at the top with a small screwdriver i kept turning the fan slightly until i could see a group of black cables clipped together through a gap in the fan blades. (Just right of centre at the front, nearest to you)
One of the cables was raised out of the group so i pressed down firmly on it and it is no longer catching the fan blade, been perfect since.
You may need a flashlight to shine into the vent
Hope this helps
这个答案有帮助吗?
得分 0
添加一条评论
What was the sound like exactly? Was it loud? Was it a constant noise? I hear random noises from my console as well and I tried looking for this but saw nothing
这个答案有帮助吗?
得分 0
1条评论:
完成的
添加一条评论
添加你的答案
Atraks 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 160
总计 12,324
