Can I add a logic board with a GPU?
Can I add a 2014 MBP logic board with a discrete GPU to a 2014 15” MBP that only has integrated graphics? or is the frame and or screw holes different?
The IG and DG models are very similar! So you could swap out your IG logic board with a DG board but you will also need a new heat sink.
Now the bad news ;-{ I think you’ll find a used system for less! Check eBay
Here’s a price list for reference: Mid 2014 15” MacBook Pro Logic Boards
Here’s the guide MacBook Pro 15" Retina Display Mid 2014 Logic Board Replacement
这个答案有帮助吗?
Yikes, those prices aren't pretty. Thank you for your help!
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 23
Has your GPU failed?
由 mayer 完成的
