跳转到主内容
修复Nintendo Switch Joy-Con控制器的指南和信息。
167 个问题 查看全部
Motherboard clip fell off during a repair
I was repairing a joy-con with a drifting joystick and when I went to reassemble everything I found a tiny piece of plastic that is the clip for one of the ribbon cables.
Has anyone had this happen before (with any device)? I’ve tried to put it back on quite a few times with success.
Any tips and tricks or do I need a new motherboard?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
generally, those pieces are like latches and pivot on one end. When pushed down they secure the ribbon against the contacts. If the pivots have broken off, the best you can do is to put it back on top of the ribbon and try to secure it with some stiff super strong packing tape. You might add a piece of foam as you assemble it to try to put pressure in it.
这个答案有帮助吗?
得分 2
2条评论:
@amber and if that does not work you will have to replace the connector. Find a broken motherboard online and harvest the connector from that. It'll require some soldering but can be done.
完成的
Thanks for the reply, @ruggb and @oldturkey03! That tiny piece ended up being dropped on the carpet after the hundredth attempt at re-attaching it. It was never seen again.
Ultimately, I ended up just swapping the motherboard from a scrapped joy-con which did the trick after weeks of attempts and loosing a part smaller than a grain of rice.
完成的
添加一条评论
Anyone know where to buy these clips or the whole connector that is on the motherboard to hold the joycon ribbon cable in place?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amber Taus 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 20
过去 30 天: 140
总计 3,711
