Can I use it as a display only?
Is it possible to connect a mac mini to my iMac and use its display? How can i do that, what will i need and are there issues that i might face?
Update (07/31/2021)
Will i encounter issues like the following?
- The iMacs display will be at maximum brightness
- iMacs fans will run at full speed because of the heat
5条评论
You can use the brightness keys on the Mac Mini's keyboard to adjust the brightness. I'm not sure why the iMac's fans are running at full speed.
由 Andrew S 完成的
@andrewsawesome have u actually tried to make the brightness adjusting from the mini keyboard and it works?
由 genik 完成的
@genik I don't have an iMac. You can also use the Display Preferences on the Mac Mini.
由 Andrew S 完成的
@andrewsawesome on what Mac have u tried your suggestions?
由 genik 完成的
I haven't tried my suggestions.
由 Andrew S 完成的
