跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。可選GSM/CDMA,eSIM/nano-SIM,64GB/256GB/512GB,銀色/金色/太空灰色。讀法是“iPhone Ten S"。
20 个问题 查看全部
Why won't my iPhone turn on or recognise charging?
My iPhone XS that was previously working just fine one day turned off and now does not turn back on. I’ve cleaned out the charging port, however it doesn’t show the charging / low battery symbol when on charge. I have a USB voltage / current reader that monitors the current draw etc. I’m not sure if this is normal but it is being given around 5v but no current draw. If I try to power on the phone with the buttons, I get a momentary 0.3a current draw for about a second, then back to 0. I have ideas it maybe a battery issue that could be the culprit but the battery health has been pretty good. There’s no water damage and as far as I know it hasn’t even been opened. Any ideas would be helpful, cheers.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
This might be hardware issues I saw many iPhone x/xs/xs max automatically shut down and while repair found shorting. There might be some shorting might be. I think that is the fault related to hardware that can`t be solved from the outer side like charging etc.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brandon Frost 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 81
